Re: H steering BAD!!
Posted by Bob M on February 03, 2013 at 08:24:47 from (74.67.191.60):
In Reply to: H steering BAD!! posted by metalmender on February 03, 2013 at 07:33:11:
Reasonably priced bolster shaft bushings and gearbox seals are available from Carter & Gruenewald. (I'm not in any way associated with C&G - just a satisfied customer...)
While you've got everything apart check for worn worm shaft bearing/bushing, worn gears, sloppy steering shaft U-joint bushings, etc. and replace as necessary.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
