Re: Coil Check
Posted by old on February 03, 2013 at 11:06:55 from (209.86.226.61):
In Reply to: Coil Check posted by Bud W on February 03, 2013 at 10:04:09:
Hot wire it. As in run a wire from the ignition side of the battery to the ignition side of the coil. Start it up and see if it shuts down like is has been doing to you. If it does not then your problem is from the coil back. If it still dies on you then it is from the coil forward but not likely to be a bad coil unless it is very hot to the touch
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
