Re: Coil Check
Posted by Bud W on February 03, 2013 at 14:35:11 from (70.242.114.188):
In Reply to: Re: Coil Check posted by Janicholson on February 03, 2013 at 14:08:23:
Thats what must be happening. Just rechecked everything and I'm thinking the problem is the switch and here's why. About half the time I pull the switch out and check voltage at the coil I have nothing. When I do have voltage it is either 12 volts with the wire to the distributor disconnected or "4 " volts. In either case the tractor will not start. I'm thinking with the bad switch I'm either not getting current flow at all and when I do there's too much resistence and the tractor will not start with 4 volts to the coil. Make sense?????
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
