Posted by charlieu on February 03, 2013 at 15:41:25 from (209.131.224.80):
In Reply to: d282 head crack posted by 756puller on February 03, 2013 at 13:02:54:
The KW Metallic block sealer works good for me. The instructions have to be followed correctly. The inside of the cooling system has to be cleaned and backflushed thoroughly removing all traces of antifreeze. The sealer then needs to be mixed in a bucket with some water before it's dumped into the cooling system and then topped off with water. Run the engine until the engine cooling system is up to operating temperature. It's then time to drain the solution completely from the cooling system, and let it set overnight to dry. Those are the highlights as I remember. It's been a few years since I have used it, but I know that there are a couple cans out in my shop on the shelf. Good luck!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
