Re: 300 differential growl
Posted by pete 23 on February 03, 2013 at 18:06:02 from (74.32.229.189):
In Reply to: 300 differential growl posted by Zachary Hoyt on February 03, 2013 at 13:59:39:
Oh the fun of setting ring and pinion. I would try very hard to set the backlash to what the supplier measured when he took it apart. You want a toe bearing on drive side and centered in the old wear pattern. Realize also, the usable area on both gears does not extend way down to the bottom of the groove between the teeth therefore the pattern should be somewhat toward outer portion of tooth. Put a load on the ring gear and turn pinion when testing pattern. Backlash is easy to set, depth of pinion is the difficult part. Most new gears are basically flush on the heels and never should the pinion be into the ring gear beyond flush.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
