Re: Farmall M assembly line scedual card
Posted by screwstick on February 03, 2013 at 21:14:17 from (174.24.55.76):
In Reply to: Farmall M assembly line scedual card posted by Jeff47o4 on February 03, 2013 at 20:57:02:
I've looked through lots of IH material, but I've never seen a build sheet before. Thanks for posting this, hope you get some leads on the tractor!
This post was edited by screwstick at 21:33:10 02/03/13.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
