Re: Coil External Resister
Posted by Janicholson on February 04, 2013 at 09:09:24 from (199.17.6.208):
In Reply to: Re: Coil External Resister posted by Bud W on February 03, 2013 at 20:09:32:
Mount it on the same bolts that hold the coil. The one I indicated has a nice mount that works.
On a Super C there is no bypass. If you really want the bypass you need to remake the starter to use a relay and small push button. Jim
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
