706 head gasket question
Posted by TJF on February 04, 2013 at 16:43:58 from (72.161.234.180):
Ok i have a 706 diesel that was blowing water out the radiator. So i figured busted head well i was correct bust all over. So i had one that was good no cracks after magnaflux. I installed it and now i think im blowing water worse than before. The head was resurfaced and valves redone. I used a felpro gasket set and torqued it 15 lb incraments after the first 50 lbs. Any ideas i was told to use coppercoat on the gasket? thanks
