Re: positive to negative ground
Posted by teddy52food on February 04, 2013 at 17:36:51 from (184.94.175.179):
In Reply to: Re: positive to negative ground posted by Zachary Hoyt on February 04, 2013 at 14:20:54:
When you reverse the current in both the armature and the field, the rotation stays the same. In a starter with permanent magnet fields, if you reverse the armature current, it will turn backwards.
