Re: Tractor id
Posted by Lmack on February 04, 2013 at 17:45:28 from (24.131.58.167):
In Reply to: Tractor id posted by Mlb907 on February 04, 2013 at 15:07:14:
Your main frames are C-254 A cultivators. The tool bars are modified for vegetable cultivation. The front tires look to be oversized probably for high flotation in soft soil. Look at the motor and verify if it is overhead valve or flat head. Some folks think I am crazy to ask but I saw a flat head C owned by a near kin. Check out the link to see a good picture of the cultivator.
