Re: 263 engine without sleeves
Posted by Janicholson on February 04, 2013 at 18:44:22 from (74.60.94.18):
In Reply to: 263 engine without sleeves posted by doorman on February 04, 2013 at 18:12:12:
Rings are machined to be a medium press fit into the block, and just a few thousandtha smaller in ID than the bore. they should stick out of the block about .004" They can be made from mild steel as there is virtually no wear at that point. When installed, the rings are then machined and honed to the piston fit. Jim
