Re: A's brakes
Posted by Dennis K (WA) on February 04, 2013 at 18:53:17 from (24.21.78.195):
In Reply to: A's brakes posted by ronztractor on February 04, 2013 at 18:29:05:
Remove the final drive as an assembly. Separate at where the brake rod enters the housing. If wet with oil, replace the seals while you are there
Dennis
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
