Re: Tractor id
Posted by gene bender on February 04, 2013 at 20:00:43 from (67.55.226.151):
In Reply to: Tractor id posted by Mlb907 on February 04, 2013 at 15:07:14:
Its an early C with wide front and the hard to find veggie cult could do rows 15 on center on up to 6-15 or any combination in between. Those cults are hard to find. They also had them for the A,SA,SAV,B,and BN. I have two of them for the A. Many types of shovels were also available along with disc hillers. I also have the 4 row fert attchment for the A. Holders for the rectangle shaped shanks are even harder to find. Yours need a restoration for showing. Last cult like yours brought 450.00 and went from Calif to Ohio on ebay. They also had a model for the Cub that did multiple rows.
