Re: Super C hydraulic valves stuck
Posted by gene bender on February 05, 2013 at 02:55:19 from (67.55.226.151):
In Reply to: Super C hydraulic valves stuck posted by Don Mountain on February 04, 2013 at 20:01:22:
I would disconnect the control rods AT the unit then move the arms on the unit to see if they are free as probably the control levers are froze. The round covers can be removed and you can spray some WD-40 or something are probably froze not uncommon. Be carefull moving the levers as you can shear the small pins that lock them to the shaft.I use a wrench on the arms where the rods connect.
