Re: Super C hydraulic valves stuck
Posted by mkirsch on February 05, 2013 at 05:29:54 from (64.80.110.74):
In Reply to: Super C hydraulic valves stuck posted by Don Mountain on February 04, 2013 at 20:01:22:
If the rods flex, then it sounds like the spools are stuck. I have no idea why they would be stuck, because they run in oil and should not rust.
You'll have to drain and remove the hydraulic unit to access the spools.
