I appreciate the feedback. Your thoughts are similar as mine, yet I wondered if the flow/pressure regulator was acting up causing more input than return, thus the overflow up the column. It is not a trickle of fluid but a considerable flow. I have (from owner)the original owners and parts manual from 1956, quite yellowed and only cost $1 and $2 respectively at the time. The IHC illustrations call out several o-rings in the column shaft but I have concerns about the sandwich style thrust needle bearing assembly, the internal cylinder valve and it's small pieces and any trouble I might encounter dismantling and reassembling the upper column shaft. I assume (and hate to) that it would easier to remove the entire shaft from the lower housing at cam sector and bench repair. Too many unknowns to just dive in with high hopes and end up making the situation worse. These older tractors can be cantankerous and troublesome if not dealt with care and skill. And parts for these early PS systems are terribly scarce and extremely pricey. Seals and O-rings I can source easily from my own inventory, IHC or locally. And just as an FYI; the current on-line IHC catalog illustrations and PNs are still almost identical to the original publications. Don't see that much any more. Any help is appreciated. Thank you Jim L.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
