Re: Trying to find JimN for help w/ IH350 Utility PS
Posted by Janicholson on February 05, 2013 at 20:53:22 from (74.60.94.18):
In Reply to: Trying to find JimN for help w/ IH350 Utility PS posted by JimL_Texas on February 05, 2013 at 19:20:44:
There is a seal at the top of the column. Below that is the sensor section with a valve arrangement.
The valve directs fluid under pressure through steel lines to a cylinder that has a rack gear which rotates the steering arms to the drag links going forward.
I believe the seal is the only device keeping fluid in the column. It is not under great pressure, as it is in the return (discharge) side of the valving. It will leak, I have replaced them with a seal from Motion Industries after removing the old seal (25 years ago, so memory and crisp imagery are lacking). (difficult) I used a small ice pic to make a hole in the metal
og the seal and used metal screws to pull it out up the shaft. (#6 deck screws might be best)
I put the new seal on a polished up section of the shaft that was just a little ways away from the original wear groove. I is still not leaking.
Good luck getting the steering wheel off.
Jim
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
