Re: Liftall hyd pump farmall H
Posted by The Red on February 06, 2013 at 09:40:22 from (206.246.187.68):
In Reply to: Liftall hyd pump farmall H posted by Howard Junkin on February 06, 2013 at 08:38:06:
Yes Howard. You will need a long flat bar or large screwdriver to stick down the inlet pipe so the gears won't rotate when you try to remove the coupler.
