Re: Liftall hyd pump farmall H
Posted by pete 23 on February 06, 2013 at 16:23:23 from (74.32.229.189):
In Reply to: Liftall hyd pump farmall H posted by Howard Junkin on February 06, 2013 at 08:38:06:
Putting a bar down the filler will only get you down into the reservoir. You would have take the pump out of the reservoir to insert something into the inlet of the pump to get into the gears. So, with the entire unit intact, use a brass drift and give the coupler a rap, several maybe, or use an air wrench with a made up adaptor. It is regular right hand threaded .
