Most likely cause is draft sensing arm coming up from lower shaft has jumped past the pickup lever inside. Take rear third arm plate off to get in to get it back in place. Often happens when backing up with something like a snow blower giving negative draft sensing movement inside mechanism. May require some ingenuity repairs like welding washer on link to prevent it from happening again. Some times just moving the vertical arm over a bit will cure them but that also require removal of pto to get to the u-bolt clamping arm to torsion bar.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
