Re: Trying to find JimN for help w/ IH350 Utility PS
Posted by Paul in MN on February 06, 2013 at 18:42:09 from (174.20.119.157):
In Reply to: Trying to find JimN for help w/ IH350 Utility PS posted by JimL_Texas on February 05, 2013 at 19:20:44:
Jim,
Maybe it is time to think outside the box (pun intended!). The PO of my 300 U w/PS evidently had the same problem with the upper seal and solved it by removing the small pipe plug (1/4" NPT)? and installing a brass elbow with copper tubing dropping down to the tranny cover and back up to the top of the hydraulic tank with similar pipe plug there also. So the old seal leaks and the oil goes back to the hydraulic resevoir. PS works fine, and the fix is cheap and easy. Maybe if the seal is completely shot, the copper tubing may not handle enough oil flow. But mine hasn't made a mess for the 30 years I've owned it.
Good Luck,
Paul in MN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
