Re: Re: Re: H jerking in gear - too much play
Posted by H MN on November 06, 2000 at 08:34:04 from (63.253.194.231):
In Reply to: Re: Re: H jerking in gear - too much play posted by PatB on November 06, 2000 at 06:36:40:
PatB: Is this the same question asked last week? You did try checking the movement in gear and engine off so try that on another H to compare. To reduce this "loose" effect try using a gear lower and the engine at a higher RPM. You may have play in the coupling to the tranny along with lots of wear in bearings and gear teeth etc. A drive train that has lots of wear? It still could run a long time that way. 3ed gear often does NOT get as much use..try it. harvey
Post A Followup
: Re: Re: Re: Re: H jerking in gear - too much play
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
