Re: 12 hole weight bracket bolt size for mounting?
Posted by rustcollector on February 07, 2013 at 19:47:58 from (70.196.34.5):
In Reply to: 12 hole weight bracket bolt size for mounting? posted by Farmall-h on February 07, 2013 at 17:18:51:
I believe that 3/4 nc is correct. The length will depend on whether the bracket is the steel welded construction or the cast bracket that was used on later tractors. The welded bracket should have a 2 inch or 2.5 inch length. 1/4 Lock washer + 1/2 inch steel bracket plus a minimum of 1 inch of threads into tractor. Check the parts listing on the web for the IH "Official" length.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
