Re: A Blue tractor problem
Posted by old on February 08, 2013 at 14:20:38 from (209.86.226.11):
In Reply to: A Blue tractor problem posted by Leon Torkelson on February 08, 2013 at 14:11:05:
I was going to answer you in the ford forum but since I see it here I will here. Good chance the ballast resister is bad since it starts and runs as long as you hold the switch. Many engines are set up to by past the resister so as to give a stronger spark for starting
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
