Posted by gene bender on February 09, 2013 at 03:08:25 from (67.55.226.151):
In Reply to: Brakes on Super A posted by nh8260 on February 08, 2013 at 21:07:22:
Remove the final drives and the bands are rite there. I remove the wheel then use a cherry picker to remove the final as its heavy. Important to have the chassis secured to keep it secure. You will want a cherry picker as the drivers whell has the cast center and is very heavy.If the seals are leaking the outer ones can be replaced by removing the drum and taking the diff shaft out thru by removing the plate on the final.. Mite also be a good time to replace the lube in the final by removing the bottom housing on the final then replace with 90wt thru the plug located at the bottom of the finaljust above the pan you removed to replace the lube.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
