Re: TD9Head Gasket
Posted by sflem849 on February 09, 2013 at 08:59:37 from (69.197.84.39):
In Reply to: TD9Head Gasket posted by mike farmer on February 09, 2013 at 08:33:50:
It is probably a cracked head. When you call for the gasket call it a WD-9 and it will be easier. The motor parts are all the same.
