Re: A Farmall with one bottom plow
Posted by Harvey 2 on February 09, 2013 at 12:00:34 from (74.128.149.135):
In Reply to: A Farmall with one bottom plow posted by Mo in NE Tx on February 09, 2013 at 11:45:52:
Looks like some one took a plow for C or B Allis Chalmers and made it to work on your A. All of the plows I have seen and Used on model A used the draw bar turned backwards to hitch front of plow and used a chain from the rockshaft to lift it.
Looks like they done good work on building it.
