Re: ih td340 crawler with 166 diesel engine glow plug.problem
Posted by pete 23 on February 09, 2013 at 12:22:51 from (74.47.40.242):
In Reply to: ih td340 crawler with 166 diesel engine glow plug.problem posted by farmall help on February 08, 2013 at 21:58:36:
No resistor on those engines and they are hooked in parallel. In other words, hooking one directly to a 12 volt battery would not hurt it. However, high voltage like having a booster charger on it will fry them in seconds. Never exceed normal regulated voltage which would be about 14.5 volts. Even that high is not good. What I do on all those style glow plug engines is keep them on while cranking and after starting but do not let go of them and then reapply. The original generators did not have enough output to raise voltage to regulated voltage while holding glow plugs but once you let go then the voltage will rise. With an alternator you could very well reach regulated voltage even with glow plugs on. So, if you have correct plugs, only high voltage would blow them.
