transistor ignition
Posted by karl f on February 09, 2013 at 19:08:12 from (172.163.26.164):
Saw mention of the Delco transistor ignition option in my 656 I&T manual. I don't remember mention of it in the operators manual. I was wondering about its lack of popularity and googled it. Seems moisture intrusion and heat were detrimental to it when used in the GM cars from the factory. Heat and water are 2 things a tractor gets a lot of--so likely even more problematic than in a car! also the germanium transistors used were not as good as today's electronic components.
This is not HEI, but an earlier attempt at high voltage ignition. It was stock in some cars around 64-70.
Has anyone been around a tractor with the Delco transistor ignition? How long til it got thrown in the junk and replaced by a regular points distributor?
-karl f
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
