Re: farmall 100 flr wheel
Posted by Russ600 on February 09, 2013 at 20:06:52 from (216.238.232.187):
In Reply to: farmall 100 flr wheel posted by Timothy Head on February 09, 2013 at 19:16:36:
Hi.
I would be concerned that the flywheel could out of balance. If the balance is ok, it should work just fine.
Cheers
Russ
