Re: Old disc
Posted by Tom Fleming on February 10, 2013 at 04:32:26 from (67.20.233.75):
In Reply to: Old disc posted by RTIND on February 09, 2013 at 11:09:55:
I am with Old. Invest in a $9.95 propane soldering torch. Should be enough to do the whole thing. A little heat, then "pump 'er up".
I do that all the time with older fittings that I am not going to dismantle. Works well. Just make sure you start with a "clean" fitting. Also, make sure the check ball is working, and not stuck "open" and filled with grit. If that is the case, replace the fitting before proceeding.
