Re: TD9Head Gasket
Posted by Red Mercury on February 10, 2013 at 08:41:58 from (204.112.36.108):
In Reply to: Re: TD9Head Gasket posted by D. Schwantes on February 09, 2013 at 21:48:03:
The stock D335 and D350 used the same head gasket UNLESS that D335 had 4.5" overbore sleeves put in it then there is a different head gasket used for those overbore sleeves only. The overbore sets were not common in my area so I never have had to worry about using the wrong gasket. The D335 overbore head gasket if used on original D335 4.4" sleeves or a D350 will rest on top of the firewall of the sleeves causing serious problems. I have a really good explanation of the head gasket & sleeve differences from Weber Tractor parts that I can send to anyone who wants it.
