Re: 666 alternator
Posted by Brownie 450 on February 10, 2013 at 13:17:35 from (66.43.241.198):
In Reply to: 666 alternator posted by Bradiniowa on February 10, 2013 at 13:00:00:
Try disconnecting the large terminal first & see if there is a spark upon the disconnecting. If you have a small ammeter, put it between the disconnected wire & the large terminal on the Alt.
Read current draw--if any. If there is small draw here, rectifier is bad in alt.
If no trouble here, re-connect wire, & pull out 2-terminal connector on alt. & see if battery discharges. If no discharge on batt. now, regulator is probably at fault.
