Re: 706 steering wheel
Posted by Retired Farmer on February 10, 2013 at 18:59:17 from (207.200.116.5):
In Reply to: 706 steering wheel posted by Farmall-h on February 10, 2013 at 18:23:35:
I used to have one but I never messed with the wheel. Are there two threaded 5/16 holes on either side of the shaft? That is where the puller bolts would go. Probably rusted to the shaft.
