Posted by gbs on February 10, 2013 at 19:39:46 from (71.51.250.1):
In Reply to: 666 alternator posted by Bradiniowa on February 10, 2013 at 13:00:00:
if yours has a 10 si delco unplug the 2 wire plug check for voltage at the plug itself with ign switch off,one should have voltage all the time the other only when ign. is on, it's the exciter wire for the regulator, if voltage is present with the switch off it will keep the alternator switched on killing the battery grave yard dead, some tractors use an oil pressure switch to control it not sure which one yours uses
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
