Posted by pete 23 on February 10, 2013 at 20:37:19 from (74.47.40.242):
In Reply to: 706 steering wheel posted by Farmall-h on February 10, 2013 at 18:23:35:
Supposed to be a nut holding wheel on. Then two 1/4 inch or 5/16th inch fine threaded tapped holes for puller. The best puller I ever found, and I have a regular wheel puller, is a half inch thich piece of iron, about 1 1/2 in wide,just long enough to fit inside of wheel. Drill two holes the distance holes in wheel are apart. Now, those threads will strip real easy so get a bolt long enough to go through the iron and bottom in threads. Add washers under bolt head as needed to accomplish that. Tighten bolts cautiously, tap gently on iron over shaft,add thin washers and continue. Use penetrating oil on shaft. Pulled many a wheel that way rusty and new.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
