Re: Hydraulic repair cost????
Posted by The tractor vet on February 11, 2013 at 18:55:22 from (75.19.114.143):
In Reply to: Hydraulic repair cost???? posted by oldtanker on February 11, 2013 at 17:39:28:
There is not much you can do with those valves , like said a couple O/rings and the unlatching piston and no need to remove from the tractor . You remove the linkage under the seat then you unscrew the valve and remove it from the body . Then you replace the O/Ring in the ft. part of the body and then it is to the vice and ya had best STUDY the book on the rest. This way you just need a couple O/Rings and the unlatching valve .
