Re: 1000 rpm PTO
Posted by Jim Naden on February 11, 2013 at 23:57:18 from (12.74.49.124):
In Reply to: 1000 rpm PTO posted by caseyc on February 11, 2013 at 15:10:11:
It's not a drop in swap in a 15.
There are differences in the PTO input shaft sizes and linkage is different unless you get a later PTO with the hydraulic applied brakes.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
