Re: 1000 rpm PTO
Posted by mkirsch on February 12, 2013 at 05:14:59 from (64.80.110.75):
In Reply to: 1000 rpm PTO posted by biggerred on February 11, 2013 at 11:32:39:
Yes, there are problems with running a 540 implement off the 1000 PTO at "half throttle."
For one, the adapter throws off the angles of the universal joints, so you will probably get chatter when going around corners under load.
It's also much harder to maintain a constant speed at 1/2 throttle. This is particularly evident when running a PTO generator. The engine doesn't react quickly enough to the governor when more engine power is required, and ends up surging up and down.
If it's working for him, then good for him.
