Posted by CNKS on February 12, 2013 at 14:33:53 from (216.144.104.128):
In Reply to: Steering rod posted by JerryRV on February 12, 2013 at 10:42:12:
Take the hood off and check the U joints. There could be a broken key. If the rod turns under the grill top, remove the grill and check the turning into the upper bolster, then take the plate off the top of the bolster, that will expose the gears. If they are ok then raise the front end and turn the front wheels side to side and have someone look at the rod/steering wheel. If it does not turn, the shaft is broken. This is a rare occurrence and is usually caused by the front wheels bouncing on rough ground. I broke one because of that.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
