Re: WD-9 firing order
Posted by AJB-830 on February 12, 2013 at 17:18:40 from (50.105.138.226):
In Reply to: Re: WD-9 firing order posted by green mann on February 12, 2013 at 11:32:01:
You need to also check that the rotor points to #1 cylinder when it is on TDC. I got a WD9 from a neighbor once who couldn't get it running after his son put points in the mag. Found out that he put the mag on 180 degrees out of time. I put the mag back on in the right spot and tractor started right up. Al
