Re: sickle mower mid mount on Super A
Posted by Dave Sherburne NY on February 13, 2013 at 08:43:18 from (50.48.48.197):
In Reply to: sickle mower mid mount on Super A posted by crlndy on February 13, 2013 at 06:24:16:
This site will figure the diameter of the pulleys you need. I would be afraid that you might have to make the driven pulley so small that the pulley wouldn't have enough surface area and the belt would slip. If you can shift down a gear or two maybe you can leave the driven pulley alone. OR go to chain drive.
