Re: Stuck Farmall M Engine
Posted by mkirsch on February 13, 2013 at 09:45:20 from (64.80.110.75):
In Reply to: Stuck Farmall M Engine posted by Don Mountain on February 13, 2013 at 09:00:16:
Turning the engine with the crank...
The crank mechanism should turn freely on its own. It's spring loaded so you have to put the crank on, push in a little, and turn slowly to engage the tractor's engine.
If you can't turn the crank mechanism on its own, and can't push it in, it is not even touching the engine and trying it is a total waste of time.
Jack one rear wheel off the ground, put the transmission in 5th, and rock the wheel back and forth.
Also before you go dumping a bunch of junk in the cylinders, dip each one with a dry stick or wire, through the spark plug hole, to see if there is any water in any of them first.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
