Re: Stuck Farmall M Engine
Posted by old on February 13, 2013 at 10:01:18 from (209.86.226.54):
In Reply to: Re: Stuck Farmall M Engine posted by Don Mountain on February 13, 2013 at 09:50:52:
On many of the Farmalls I have the hand crank parts have sat so long and not been used they do not turn by hand so good chance that is your problem there. With the plugs out and the fan belt tight you should be able to grab the fan and turn the crank that way. I do that on all the tractors I buy the check of a locked up engine. Ya some times you have to push on the fan belt with one hand to tighten it and pull with the other hand but that does work. Yes you will not turn it much but just a little bit tells you the engine is not locked up
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
