Re: Farmall400 with 61 hp
Posted by D Slater on February 13, 2013 at 16:11:15 from (184.15.14.56):
In Reply to: Farmall400 with 61 hp posted by realolman on February 13, 2013 at 15:00:09:
Depends on what you want to call stock. Thats in the area of what a 400 with 4-1/8 bore firecrater pistons in it could make at sea level. some a little more.
If running a higher grade gas, timed for max power and in great tune it can with the 1/8 over stock pistons.
But unless you see tractors run on the same dino with the same person calculating readings the same every time I wouldn't worry about comparing power.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
