Re: Farmall b project
Posted by gene bender on February 13, 2013 at 19:34:14 from (67.55.226.151):
In Reply to: Farmall b project posted by Zeke5738 on February 13, 2013 at 17:40:18:
Drill small hole and then use sheet metal screws and it should pop rite out. How are the one in the final does it need replacing also.
