Re: Farmall b project
Posted by ralph1111 on February 13, 2013 at 19:38:11 from (204.12.181.71):
In Reply to: Farmall b project posted by Zeke5738 on February 13, 2013 at 17:40:18:
I replced seals in mine last year. I used a home made slide hammer to remove old seals. Just weld a angel on the end that will fit through seal and pop them out it's just that easy.
Ralph
