Continue by staring the tractor and lifting 3 point hitch on the position control lever and gauge the amount of spool and lever movement!!
Then add your weight and lift again, comparing spool and lever travel (s) which should be the same!!
Do not!! At this time alter the spool adjustment and do not!! Attempt to adjust the drop check valve!!. The drop check appears to be correctly set !! The info from the I & T manuals on how these adjustments are done, appears strange ??? And not how we did them in the factory !!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
