Posted by CNKS on February 14, 2013 at 19:11:16 from (216.144.104.128):
In Reply to: SA Water in Oil, part 3 posted by Farmall dean on February 14, 2013 at 12:40:37:
If it snapped when tightening at 80 ft lbs, it must be very rusty, or you did not clean the threads first, meaning your torque readings are not correct. Those things usually break when you have the head off and are trying to remove the studs. If it broke inside the head there should be enough left above the block to be able to remove and replace. You probably need all of them. On those gaskets you don't need high tack, I have overhauled a C, SA, SH, and 460 -- copper coat works fine, they don't leak.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
