Re: B-414 1850 loader
Posted by Cyrush on February 15, 2013 at 04:57:00 from (109.156.55.88):
In Reply to: B-414 1850 loader posted by De Castro on February 14, 2013 at 16:54:53:
Hydraulic pressure should be o/k @ 2500psi.
The main concern i can see is lack of oil capacity (volume) from the hydraulic reservoir!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
